No, hold both pedals to the floor (brakes and gas) then your rpm should hold at ±2700rpm, then let go of the brake pedal and BAM!!!All R's up and hold gas peddle to 3k
You do not hold the rpm level, the car does. Just floor it and it will hold it for you below 3K.All R's up and hold gas peddle to 3k
??? if you can read, he just said it lunch with no BOG ???No, he probably has LC2. Apparently some can get to 3,000. I don't know why, but mine did NOT, and it would get to 2,500 or so, and when I would launch, it would BOG and it would just be a crappy launch. I gave up as I was better off just hitting the gas. Now I have LC5 and I can launch properly.
Re read what people post and proof read! I said "Apparently some can get to 3,000." If you search the majority of CBA cars with LC2 cannot launch properly and it is due to Nissan "castrating" the Launch Control on the car due to the 2009 breaking transmission problems that were a big problem up to that point... Mine would try to launch and it would fall on it's face and bog hard around 2,500 RPMs every time. When I loaded LC5 VDC OFF I can launch just fine now as long as I have VDC OFF on the car. Again, some lucky CBA cars can use LC with VDC ON (R R R). But that is the exception and not the rule.??? if you can read, he just said it lunch with no BOG ???
I just visited acme.com, and I could not locate this sling shot you speak of... Please link.Best way to launch it is to get yourself an ACME rocket and sling shot and make sure Wile E. Coyote is there to help you out if you have any further questions. Hahahaha jk![]()
