1 - 11 of 11 Posts
Hoosier makes the 17" and M & H recently came out with the 28X10.5X18 ( which can be run on all 4). What's the best short time to expect from either of these before switching brakes and running 15's in the rear?
Does anyone know if they set up the ETS differently to achieve these short times?
Yes Jack trans sells a billet set up with upgraded front clutches for these times.
R35 member
Ive gone 1.31 on M and H 18s. Stock ETS and rear diff
To my knowledge they only upgraded the clutches in the trans w shep. I will ask them if you want to know.....
Thanks for the response. I'd like to know if the front end is happy with a little more power and are the cars frequently street driven.
R35 member
That's bad ass. 18's on all 4 corners? Any suspension work?
I had to put the car back to stock height to fit the slicks under the front without rubbing. They actually fit and work while lowered, but when I launched, it pulled the left front wheel off the ground slightly, and when it came down, it launched the parking light out of the fender.
Joe
1 - 11 of 11 Posts
