The trick is to shift so that the "area under the curve" is the greatest. Shift too early, and the rpm you get to after the shift is too low, so you aren't near peak hp enough to take advantage of the fact that you were at, or slightly over peak hp.
500 rpm over peak sounds fair as a good shift point, but depends on power/torque required for the next turn too. "overselecting" for the next corner puts me in an area of the torque curve where I can apply power very early without oversteer. This smooths out the corner and shaves tenths off laptimes. Each track is individual, though.
