1 - 13 of 13 Posts
Can anyone tell me what the advantage is with filling tires with nitrogen? And what would you ask a local tire store in order to see if they are competent enough to change out your tires because I understand the rays wheels on the 2012 have these knurles on the rims to keep the tires from slipping. Is this really important to have? Thanks
Nitrogen - cheap inert gas. Low reactivity, and expansion/contraction is less. Other gasses have been tried (Ferrari did some fluorocarbon once), but are too expensive for regular use.
There is no good "test question", but asking what kind of equipment they use is helpful.
Nitrogen also hepls prevent the tire pressure sensors going off all the time with little change in pressure, My BMW tire pressure sensors would go off all the time.
Try to find a high performance shop to change the tires.
Yeah I know what you mean..my BMW tpms went off all the time when the temperature drops below 55 degrees here in southern California. I am glad to know this bc I don't want to gomto the dealership to buy tires when the time comes. I just hope "high end" tire shops won't charge just as much as the dealership for tires and mounting. Thanks guys for the help
Nitrogen's benefit in road tires is rather oversold, and mostly by companies who can make a profit by selling you nitrogen. All gases obey the same gas law: PV=nRT. And if the amount of gas is constant, then PV/T=constant. And if volume is constant as it is inside a tire on average, then P/T = constant. So as temperature (in absolute degrees) goes up, pressure goes up. As temperature goes down, pressure goes down which is why TPMS sensors go off in the cold to tell you to add pressure, because pressure actually went down with the temperature. Nitrogen is no different than air. Air is made up of over 75% nitrogen, then oxygen, then a few other gases. All of these gases obey the same gas law. The only time nitrogen might make a difference is if there is a lot of moisture in the air inside the tire. The amount of moisture in saturated air depends on the temperature. If there is a condition where the moisture in water form vaporizes, it adds to the pressure, but this is a very slight effect, and would only ever be noticed by professional racers or experienced track drivers who could tell the difference of 0.5 psi in a tire. Very few drivers can tell that when pushing a car at the limit. And then this is only a problem if the air is not dried as it should be from a proper tire filling station. If there is no moisture in the air, then nitrogen will act exactly the same as air in a tire. The only other claim to fame is that pure nitrogen will oxidize the inside of the tire less than air, since there is no oxygen. If you drive your tires for 500,000 miles, this might, might make a difference. And some people think that the size of the molecules means that pure nitrogen might leak less over many, many months. I have never seen any conclusive test that validates any benefit for nitrogen for regular car use except the benefit of nitrogen vs moist air in terms of slight pressure variations. If you are racing professionally, then nitrogen makes sense, plus you carry N2 bottles to the track for other uses.
If you search for publications from even tire companies on the benefit or lack of benefit to nitrogen use in tires, you will see that while there is nothing wrong with using pure nitrogen in tires, there is very little need for it vs air. Extracting nitrogen from air takes energy which would be better saved for more useful purposes.
wow...that sure was food for thought. It has been a while since I took physical chemistry and even when I did, it wasn't my best subject. I now know that i won't have to go to the dealer for tires or air. Thank you sir
+1 Where I live it goes from about 90F to -30F degree in 4 months and I have one tire filled with air and the other three with nitrogen. With the change in temperature I never noticed any more stability in pressure from the nitrogen filled tires compared the air filled tire. Who knows maybe for hardcore track racers that do hotlap after hotlap it might make a difference but not for me.
While I agree that the benefit is oversold, you are correct about the ideal gas law.
However, there are two problems with this, the moisture that you have pointed out and the "mixed gases" problem
1. the n of atmospheric air is much higher than dry nitrogen at the same pressure inside the same space due to the presence of oxygen and carbon dioxide. Partially as a result of this and the fact that atmospheric air (even when dried) does not obey Dalton's law and the gases are not inert and do not maintain a constant intermolecular distance over the spread of pressure conspire that atmospheric air has a greater spread of expansion over the same temperature as dry nitrogen.
2. water vapor (significant in pressurized air) does not behave constantly over the performance envelope of a tire. It can go, in less than an hour in a car on track, from ice crystals inside the tire, to liquid water, to the gaseous state.
The significance comes in that a lot of people who track don't use a dried source of air to inflate tires. Home "moisture absorbers" do not do that good of a job of drying compressed air. So - get to the track, and use your portable compressor, and voila, you have added a lot of water vapor in there.
The differences are, admittedly, very small but present. I have tracked extensively on stock tires filled with Nitrogen, and one filled completely with air on my portable compressor. The difference THERE wan't small. 2-3 psi between the back tires at VIR grand east. I cannot say with dried air, but regular air was....significant.
Some info here on partial pressures and Dalton's law: http://www.bae.uky.edu/~snokes/BAE549thermo/psychrometrics.htm
And I had saved this post a while back from user pisgahchemist on eng-tips:
"as the temperature of a gas increases, then the pressure of the gas increases, but it stays a gas. A gas won't condense as the temperature increases while the volume remains constant. Consider the combined gas law: P1*V1/T1 = P2*V2/T2. If we assume that V is constant (the volume of the tire may increase by a percent or two, but for our purposes, the volume remains constant) then P1/T1 = P2/T2 which is a direct proportion: as T increases, P increases. Suppose that at 20C (293K, 68F) the absolute pressure of the water vapor in the tire is 1.00 psi, which is what it would be if the air were saturated in water vapor. Then at the temperature where the tire is operating, let's say 100C (373K, 212F), the vapor pressure will be 1.27 psi absolute, well below the 14.7 psi where liquid water and water vapor are in equilibrium at 100C. (The 1.00 psi is determined by assuming that a tire has an absolute pressure of 44 psi (30 psi guage + 14 psi atmospheric) which is about 3 times atmospheric pressure. Using a table of vapor pressures, we can determine that the equilibrium pressure of water vapor at 20C is 0.340 psi before compression.) The new pressure of the water vapor in the hot tire is calculated from:
P2 = P1 * T2 / T1 = 1.00 psi * 373 K / 293K = 1.27 psi
Therefore, we can conclude that simply raising the temperature would never cause water vapor to condense.
A compressor works by mechanically forcing a gas into a smaller volume which increases the pressure:
P2 = P1 * V1 / (V2 ) where P is inversely proportional to V. As V decreases, P increases.
If the volume is small enough and the resulting pressure great enough, then it is possible for some of the water vapor in the air to condense to form liquid water, and release heat. The heat energy that is released is the energy of motion (kinetic energy) originally possessed by the water molecules in the gaseous state. The kinetic energy of molecules in the liquid state are much less than the kinetic energy of gas molecules. And it is this difference in energy that shows up as a small amount of temperature increase in the compressed air.
But the majority of the heat energy that causes the compressed air to be hot comes from doing work on the gas by compressing it. The energy that is applied to the gas shows up as an increase in kinetic energy which of course is proportional to temperature. The air which is emitted by the compressor is still mixed with water vapor since only a fraction condenses. If the compressor is any good at all, the air goes through a dryer of some description which either allows the water vapor to combine with a desiccant (often calcium chloride), or be condensed by a refrigerator, which is the way that a household dehumidifier works.
The bottom line is that you will never have liquid water forming inside a tire that is being operated at an elevated temperature."
GTR Nerd
Good dry air is about as good as nitrogen. When money is no object, and you are using nitrogen to lift the car, and to run air tools, its fine to put in the tires. However good dry air is just about as good for 99% of the people out there.
We have run nitrogen in the race car tires at times, and I can not see any real definitive evidence of going through the hassle of using it, unless we have it.
Agree wholeheartedly. But, if starting out on track with wet air in one left rear tire, and all tires to the same pressure, there will likely be a tiny frost of ice crystals inside the tire. By the end of the first track session, the ice would have melted, and then likely gone into the gaseous state, playing havoc with the ideal gas law, because it doesn't apply to solids. You have now added even EXTRA n to the equation now.
I understand, and also agree with you and Sean that good dry air is 98.75% as good as dry nitrogen. But, vs. wet air, nitrogen is TONS better.
1 - 13 of 13 Posts
