I don't understand...engine service light came on today, was able to reset and it go away and is time to do POS service =(
Can the dealer perform the POS using the 0005 version of the AP? If so, no. <----- ouchI don't understand...
Is your question - Can the dealer perform POS, even though I have a Cobb AP tune installed? If so, yes, depending on version of tune (ask your tuner, or check with Cobb if you are using a canned tune - I believe as of v3.3, there is an ability to communicate with the ECU with the AP installed).
or
Most likely, you meant the former. I was just clarifying.
Ask your tuner if the dealer can communicate with the ECU while the AP is still installed. If not, and you would prefer to leave the tune in, I recommend asking your tuner to create a tune that DOES allow ECU communications. I am not sure if the dealer cannot do a clutch relearn if a 'blocking tune' is installed. Because this is in the TCM, and v0005 AP does not interface the TCM, I don't see why not.Can the dealer perform the POS using the 0005 version of the AP? If so, no. <----- ouch
I have large MAF don't really want to uninstall it and drive around =(
Will they able to at least do stuff like clutch relearn?
