Need some advice, particularly given that I am not a mechanic and know a limited amount about engines. My goals are not to make 1000hp but to build a rock solid car that can take the beating of a lot of track time and be fast at the strip (I am blessed to have 2 road courses within 45 minutes of my house as well as two drag strips within 45 minutes). I am considering having an engine build done this winter and looking for real world experience, and hoping you have seen this type of build before (vendors have been helpful but looking for some real builds and your experience with them). Now that I am tracking a lot I figured I need the reliability of a build and after my last scare at the track (stupid computer problem… good news engine is fine) it made me think it is much cheaper to do now vs. later and I have a long winter ahead being in the midwest. My current long block has about 14,500 miles on it and my other mods are:
Go: HKS Legamax Catback, HKS Midpipe (Catless), Kressieg Downpipes (Catless), ID 1000cc injectors, Gotboost's 3" intake system, K&N drop in filters
Tune: Cobb AP-NIS-006 with custom tune
Stop: AP J Hook Rotors, Forged SS Brake Lines, Endless MX72 (Street) Pads, Hawk DTC - 70/60 Pads (Track), Motul Brake Fluid
Solid: Shepard Transmission - Stage 2 Build - Transmission, PPG - First Gear,
Dodson - Super Stock Clutch, Gear Set, Clutch Pack and all the other goodies, Willall Fluid
Cooling: SSP Transmission Cooler, HKS Drop In Filters
Wheels: 20" forgestar and OEM
Grip: Potenza R2's (OEM Size) for Track and Daily Driving, Nitto NT05R & Nitto NT555R Drag Radials for dragstrip (20")
Handling: Eibach Sway Bars
Goals:
Goals:
- Keep the cost down (of course)
- Emerge with a rock solid 600-650 wheel HP car that can take the beating at the track (I'm thinking 20 track days next season) and run low 10.3 or under at the drag strip with my Nittos
- Finally this car is also my daily driver from April-October and I want to keep the daily driveability (I love this about the GTR, the only thing I have to do special is change tires for the dragstrip, I drive on the track with my run flats that I daily drive with).
- Pistons
- Connecting Rods
- Mainstuds
- Bearings and hardware
- Upgraded Oil Pump and filter
- Engine Gasket Set
- Cams
- Valve train locks and springs
- Upgraded turbos? Do I need to take some strain off at the road course? And if I go to the upgraded turbos assuming I need an upgraded intercooler.
- Tuning:
- Go with a dyno retune and a specifically dialed in a road course tune
- Dyno tune for a Specifically dialed in dragstrip tune
- Fuel: should I stay at 93 octane pump gas or E85 (as it is prevalent around here)
