1 - 20 of 20 Posts
Hallo I have a Nissan GTR 2020
This week I got a y-pipe from a Nissan dealership during the yearly maintenance
now car sounds better.
noticedwhen I accelerate from 100 to 180kmh the car makes a whine noise.
is this normal with a y-pipe?
At the dealership it was a normal maintenance( oil change) + ypipe. The noise/whine don’t know how to describe. It sounds like high pitch spinning sound. Only happens when accelerating at high speed
Not normal..A recording of the "whine" may help with iding the nosie..FWIW no whine on my 2020..I have the "Nissan NISMO" midpipe also....
Just tested it .
It happens when full throttle acceleration between 3-4K rpm at 40 km/h or 100kmh. Sound comes from the rear. It’s either a whistle or metal grinding noise
sounds for me like a broken gasket or they forget tighten the screws.
use smoke in this area and check if it’s leaking
  • Like
Reactions: zirgr
Most likely rubbing on the under tray and resonating at that rpm.
Oddly enough, I had the same issue, but with an AAM midpipe... I tried so hard to figure out what was making the noise, it started immediately when I got my midpipe installed but it just didn't make any sense, didn't sound exhaust related. I just had a different midpipe installed and it immediately and totally went away... same sound you describe. I'm not sure if it was incorrectly installed, didn't have a reducer, was hitting the under panel somehow... but it was a binary on/off for the sound before after the midpipe switch.
If you have a 90mm Y-pipe mating with a 76mm factory exhaust there is not much surface area for the gasket to seal and a lot of leaks appear here. The reducer gives a better gas flow with the flare instead of the "step" which would be the case without it.
I have the AAM mid-pipe coming, they said their gaskets are designed to mate the two different diameters. Just like the ETS gasket.
Hoping I do not have this noise issue.
Discussion Starter · #15 ·
So I was at the dealership they don’t have a reducer.
We put in the oem y-pipe. Now the whistle noise is gone.
i will look for other y-pipes. Probably HKS
thx everyone for the support
If you want I can send you my reducer that I no longer need. I used it without a problem before purchasing a 90mm catback. You`ll have to use a 90mm gasket on one side and you can use the factory 76mm on the other side.
Discussion Starter · #19 ·
Dealership (Nissan HPC) is to far away (130km). I only go there for yearly maintanance.
Also its not guaranteed it will work with the reducer.
Thanks for the offer
Which y-pipe are you using?
Do you have downpipes?
dont wanna change to much at the car.
Stock it sounds like a vacuum cleaner
Yeah okay.
I currently use an SBD 90mm resonated Y-pipe, it`s been on the car for maybe 8 years, no complaints. Catback is a Meisterschaft 90mm straight through no silencers.
I did purchase downpipes along with the Y-pipe but have not installed them they are still lying in the garage:confused:
I decided to use the factory downpipes to pass emissions testing every year.
The Y-pipe and catback are very easy to install yourself if you have access to a lift of some sort. You should not have to use a specialist to install a Y-pipe, it`s so simple.
I bought all of my stuff from the USA the choice is very good compared to what is available here in Sweden. DP`s and Y-pipe were new the catback was used
1 - 20 of 20 Posts
