Boost Logic 750x mops the floor at Streetcar Takeover
7.2K views 22 replies 10 participants last post by  Goonthree
#1 ·
One of our customers with one of the first 750x builds (Originally built in Spring of 2012) sent me this video last night. Customers are always wondering how reliable the 750x package is and this video is a true testament on how quality parts and a good tune can go a long way. This car is still on a stock motor and stock transmission!
http://www.boostlogi.../part-02011604/
For more information on the package
#8 ·
Car is kicking ass. It looks like it trapped 137-138 mph from a roll (not much difference vs from dig). So one would assume 26 psi should trap a little higher?
Video shows what a good reaction time, traction and consistency can do.
#11 ·
We still don't know if that's 26 psi throughout the rpm range or if it tapers up to 26. I can see if it starts around 19 and tapers up to 26 by redline. That's most likely on the stock engine. I don't know that I even want to try 26 from start to finish on a stock engine.
#15 ·
Do you think there is a major difference between c16 and e85 in terms of power/trap? Especially in the upper rpm where the torque spikes etc of e85 really arent an issue so to speak. From what i have seen c16 makes more power the e85 ever so slightly
#18 ·
for the record I am just comparing the boost pressure to trap not the fact that its below 140mph. With these turbos at 26psi it should be making some tremendous power on the stock block unless the timing is ultra super conservative but then why run such high psi, run lower with more aggressive timing.
