For just the oil cooler kit from Boost Logic I was thinking $750 for the kit since new it retails for $1400.
If you want the additional ducting adapter that I made that creates an air tight seal between the OEM plastic air duct and the larger surface area BoostLogic oil cooler I was thinking of selling that for $100. The BoostLogic kit reuses the OEM metal ring to mate up the plastic duct to the oil cooler. But the ring doesn't really bolt to the bottom of the oil cooler (kind of wedged between the cooler and the mount) and you still need to cut/modify the OEM metal ring to get a better fit. But the fit is not as good as the OEM cooler to the OEM duct. This price also includes the OEM metal ring that I trimmed as well.
If you want the modified (slightly trimmed to fit nicely) OEM plastic air duct that mates perfectly with the above adapter I made I was going to ask $50 for that.
So summary of parts/prices:
- BoostLogic oil cooler kit - $750
- custom duct adapter to oil cooler - $100
- modified OEM plastic duct - $50
For a total of $900. If you by everything you will not need to modify any of the OEM parts you would have to reuse (metal plastic duct and plastic duct mounting ring).
Pics of the custom duct can be found here:
Without the silicone molds to direct air flow to only the fins (they are easy to add or remove and come with the adapter $100 part)
With the silicone mold to direct air to only the fins
