G Sensor error VDC off R35 Help Please
1.7K views 0 replies 1 participant last post by  EmmoNZ
#1 ·
Firstly, thanks to all that share their knowledge on this forum to help others, including myself. Really appreciated!
Wanting any help with a 1161 side g sensor set error (and C1D02 YAW RATE/SIDE/DECEL G SENSOR) causing a VDC off permanently that cannot be cleared by ECUTEK or consult III.
Came from having loose battery terminals and jump starting the car, then vdc and abs error (abs corrected with ECUTEK recal)
Break fluid is checked and fine
Tried disconnecting the ground terminal for 30+min
Still cannot clear.
Could the side g sensor be fried?
The link between the g sensor and abs module or maybe the abs module its self (but no abs errors currently)?
Or could someone please confirm which g sensor is which?
98805-JF20A Side g sensor??
47931-JF00A. Decel G Sensor (under the rear centre consol) ??
Car dets:
2008 R35 CBA JDM FBO
Many thanks in advance for any help provided :)
Emmo.
