R35 GT-R turbos - IHI RHF55 same as MY06 STi Impreza
Turbocharger Type RHF55
Turbine Blade no. 11
Compressor Blade no. 6 + 6
Turbine Rotor Size 53mm / 48mm
Compressor Rotor Size 60mm / 46.5mm
Max. Turbine Speed 165000 rpm
Wastegate Open Press. 78 kPa
A/R Ratio 15
Compressor seal material Synthetic mica + Teflon
Bearing Type Floating Metal Bearing
GT-R Turbos
Smaller than say a 2530 turbo on the compressor side, a little bigger than a 2530 on the outlet.
