101 - 120 of 191 Posts
Second transmission failure:
Painful to be on the list
Model Year
USMY 2009
Relevant ECM/TCM Code(s)
p2715
Symptoms of failure
transmission went to auto mode, Even gears only, no reverse available, Check Engine Light, and Drivetrain Light
Approx ODO at time of failure
30000
What were you doing at time of failure
Second track day of the weekend at VIR with TrackDaze, at the second to last session of the second day
Mods at time of failure
Forged Performance road course tune
Replacement 2012 transmission
Forged Performance tranny build: http://www.gtrlife.c...300#entry908609
Greddy transmission cooler
Cobb catted midpipe, Agency Power Variable Exhaust
WillAll Differential cooler with custom Forged Performance plumbing
Track use pre-failure
Four years of approx six track weekends per year (approx 36 track days, average four sessions per day)
Warranty filed? Date (mm/yy) Approved?
Due to significantly modified 2012 transmission because of my lack of faith due to the FIRST failed transmission, we did not even try (failed sensor was a Dodson part)
Any thread links or other notes you might have
First failure:
http://www.gtrlife.c...ry/#entry872652
Rebuild experience:
http://www.gtrlife.c...ed-performance/
Piston seal failure? After that build - that is tough. I wish it wasn't so expensive to break it open to replace small things.
The failure was one of the Dodson early version pressure sensors, but while Sharif was putting it back together they pressure test the other seals, and one of them wasn't quite up to his standards.
A relatively inexpensive one, but of note nonetheless.
Model Year[background=rgb(246, 246, 246)] (US Assumed, Specify if global)[/background]
[background=rgb(246, 246, 246)]2009 (US)[/background]
P0847 - second failure!
Symptoms of failure
[background=rgb(246, 246, 246)]Lost 1,3,5 and R - limp mode[/background]
38,000
Reversing out of driveway, reverse felt like clutch was slipping, limp mode activated
Mods at time of failure [background=rgb(246, 246, 246)](Specifically: Reflash ECM? Reflashed TCM?)[/background]
[background=rgb(246, 246, 246)]Cobb AP (with TCM)[/background]
Track use pre-failure[background=rgb(246, 246, 246)] (miles or XX minute sessions or track days, # launches on lc version X, etc)[/background]
[background=rgb(246, 246, 246)]None[/background]
Warranty filed?[background=rgb(246, 246, 246)] [/background]Date (mm/yy) Approved?
August 1st, 2013 - waiting to hear back
http://www.gtrlife.com/forums/topic/76819-potential-horror-story-only-gears-246-dealer-refuses-to-fix/page__st__140
If this isn't fixed under warranty - I will burn Nissan to the ground, and, as another forum member mentioned, take the broken transmission out and kill myself with it
Year- 2010
Codes- no codes
Symptoms- Binding during slow speed turns( this has been going on for the year I have had the car, I thought it was normal), lost front wheel drive, broke front wheel drive output shaft.
Miles- 16,700
What was I doing at time of failure- 8th pass of the day, drag racing at Bandemiere
Mods- Full bolt on E-85, ECM and TCM flash, Ecutek
Track use- 2 full track days, around 50 launches
Warranty filed- August 1st 2013, denied August 5th 2013
I gave the warranty a shot. Was turned down due to TCM flash only. This sucks but, I new what the consequence would be if I modded my car.
If you flash the Cobb LC2 back to the GTR is that the same as the factory LC2?
I selected to save my original LC2 when flashing the TCM, but have a feeling it didnt save because when i went to load it back a while ago it looked like it was the Cobb LC2.
I had Visconti load stock lc2 back on the car and warranty was still denied. Nissan said they could see the car was flashed. What is one to do, ask for proof? And then what fight it? I want my car back so I can drive it. I will just get the car fixed and move forward.
[background=rgb(54, 54, 54)]My friend is waiting for the TSB clips and new O rings to arrive at the dealership.[/background]
[background=rgb(54, 54, 54)]I know it is a Nissan Restricted parts but it's been 8 days now and the TSB clips and O rings has not arrived yet.[/background]
[background=rgb(54, 54, 54)]Any idea how long does it take to get?[/background]
[background=rgb(54, 54, 54)]Thanks guys. [/background]
Sorry to hear that Chris!! When did it fail? Last Wednesday?
It failed on the 27th of July. Its funny how I came up to you guys looking at Robs broken car, I was saying how happy I was with my car because it had been so reliable. Oh well.
Now THAT is a surprise. I am so sorry. Were you running higher than stock boost levels? Was any detectable "tune" loaded on the car when it arrived at Nissan?
If so, then the "agglomeration" of factors doesn't surprise me. If it arrived running E85, then the coffin was in the back when you pulled up for your warranty, but what you said above makes me ask what tune it arrived with.
Was the car ever on Cobb LC flash before you went Ecutek? Maybe they can see that.
No, It didnt have any flash when I bought it.
I've got an 09 GTR with 44k miles, stock except for Cobb intakes and tune. Trans went into limp mode with only odd gears and no power. Used Cobb to reset and get to dealer. Dealer ordered/installed caps per service bulletin. Got car back yesterday and seemed fine. Drove 100 miles on highway and while getting off car locked into 5th gear. While I was trying to deduce what was going on a massive shrill went through the car like I was going into park. Sounded like two gears at once. Car came to a violent stop in the intersection with a semi car carrier behind me that shuttered to a stop 5 feet behind me. Car had service engine and trans failure lights on and indicated 2nd gear. Shut car off then started and put into neutral and tried to push but all locked up. Tried 1 and rev but no clutch engage. Cars were coming fast off ramp so I reset error codes with cobb and car started to move. Drove down shoulder in 2nd and parked at work. I'm pretty sure this trans is toast. These valve bodies are serious trouble. Still under extended warranty for another month. What are the chances of getting a new transmission?
Norm S.
Is it just me or does it look like many cars had transmissions fixed/replaced UNDER warranty even though they had mods like a Cobb AP Etc?
I thought and was told that with any mods the warranty would not be honored.
Model Year
USMY 2009
NONE
Symptoms of failure
Clutch temp light flashing and rpm's spinning up as if in neutral. Clutch basket "B" failure.
31,000 miles
Occured coming up to speed for freeway merge. No noises or smells apparent.
Downpipes and full resonated cat back exhaust, Cobb flash
none
Due to flash and downpipes, warranty was denied. 10/13
Hate to be adding to this thread, but unfortunately I can add to the list!
Model Year
[background=rgb(246, 246, 246)]AUS MY2009[/background]
P2832 - Broken Shift Fork A
Symptoms of failure
[background=rgb(246, 246, 246)]For about 2-3 months the car occasionally wouldn't shift into 6th at low speeds (~50mph or so). Would flash '5' on the dash then eventually go into 6th. This seemed to clear up with a clutch re-learn, so I never really worried about it. [/background]
[background=rgb(246, 246, 246)]~20,000 miles[/background]
[background=rgb(246, 246, 246)]Tonight after a spirited drive I casually pulled onto a highway and manually shifted through all the gears. It refused to select 6th then threw a transmission failure warning and went into limp mode. P2832 was thrown. I cleared the code to see if it was a false code. No deal. After moving off the line in 1st and selecting 2nd, the car ground to a halt and would no longer move in any gear, requiring a tow. [/background]
[background=rgb(246, 246, 246)]Full bolt-ons and E85. [/background]
[background=rgb(246, 246, 246)]LC5 run for ~10 months, LC4 v2.0 run for 2 days before the trans failed. [/background]
Lots. Circuit, drags, road coarse etc.
LOL - Not even going to try.
Brockas I had the same thing happen to me and the fix is rather simple. Dodson or Willall gear stoppers should fix that issue.
Thanks Hitman.
I'm trying the Nissan clips as outlined in the TSB (as attached) next weekend. Hopefully that should fix my issues
