Initially took the car in for a P0840 code which was deemed pressure sensor, car drove after i turn it off and on, drove for few days after. All sensors were later changed to Dodson Sensor (including line sensor). After installation car ran fine for few miles then bam!! received a P0746 & P0797 code. Entire trans was dropped again and they found small leak on clutch basket, repaired the seal with viton seal to include both input and output shaft seals. After the shop put everything back together and they clear the codes, the codes keep coming back up after driving for like few miles along. Not sure if the heat has been attributing factor or what but never had these codes until after the pressure sensors were replaced. Trans pressure seems good, VB was even sent out cleaned and tested and everything seemed to be in good working condition.
Work Done.
All Dodson Pressure Sensors
Clutch Basket Viton Seals
Input/Output Shaft Seals
Shims
Dodson Oil
Symptoms:
Car Stays in automatic mode
Power Steering Stiffs Up
Gears 1,3,5,R
2010 GTR
Bone Stock
Please any feedback would be preciate so i know what possible parts to get. Just getting frustrating think of thinking bout dropping the tranny all over again
Work Done.
Shims
Dodson Oil
Symptoms:
Gears 1,3,5,R
2010 GTR
Bone Stock
