Whats the best way to remove oxidation from inside the headlights?
1 reading
2K views 4 replies 4 participants last post by  Slimshady201
#1 ·
HELLO EVERYONE I NOTICE TODAY WHEN I FINISH WASHING MY GTR THAT MY RIGHT HEADLIGHT HAS SOME OXIDATION INSIDE AND AS WELL CONDENSATION I DONT KNOW IF THERES WATER GOING INSIDE THE HEADLIGHT IF ANY ONE COULD HELP ME OUT HOW TO REMOVE THIS PLEASE LET ME KNOW THANKS!
#2 ·
The way we used to remove the orange reflector in the Subi STi headlamps was to bake them at a low temp- 250 degrees and then pry the lens off, wipe off the silicone that was now all melted and then when we were done place a bead on the edge and reseal. The newer GTRs with LEDs may not like the oven and could cause issues.
#4 ·
You can remove the large housing cover at the bottom front of the headlight and also the small marker light at the top of the light. Point a hair dryer into the lower opening and the air will circulate in and out the upper bulb opening. It worked well on my 2012. Takes about 15 min.
